How to parse response body?
tyagisu
Mega Expert
My requirement is to get the message and type from the response body. When I get status code 500, this is the response body I have. I am using the script include for calling the rest API and then calling this API in one of the UI actions. So I need to show this message and type I get in my response body when I click the UI action.
ResponseBody:
"error" : {
"type" : "SERVICE_EXCEPTION",
"message" : "MTA may be in use and determined to be not safe to suspend."
Any help would be appreciated!
Su
Cool. Can you now replace
type = res.type;
message = res.message;
with
type = res.error.type;
message = res.error.message;
Muhammad
17 REPLIES 17
JerryJ071847183
Tera Sage
Hi, Check the below example where parsing has been explained.
https://developer.servicenow.com/dev.do#!/learn/learning-plans/orlando/servicenow_application_developer/app_store_learnv2_rest_orlando_exercise_parse_rest_response
Mark my Answer as Correct and Helpful if it helps
Thanks for your response.
My client is using New York. The above solution is for Orlando I think, I couldn't find the application.
Su
Satyanarayana C
There are two things to remember here:
1. When you send a response from Server, you should always send as a string.
    So, before returning the response convert it to a string using JSON.stringify('<response>');
2. The place where you are reading the response:
    Convert the response to a JSON using JSON.parse('<response>');
3. Once you do the above two steps:
    You need to handle the response JSON. You can read it like shown below:
    var response = JSON.parse(responseBody);
    if(response.error) {
      var errorType = response.type;
      var errorMessage = response.message;
Hi Satya,
Thanks for your response. The below solution didn't work. Can you please let me know what did I miss?
var jsonObj = JSON.stringify(responseBody);
var res = JSON.parse(jsonObj);
if (res.error) {
gs.info("Inside if:" + res.error);
type = res.type;
gs.info("Type:" + type);
Su
Prasant Kumar 1
You can follow the below script:-
var r = new sn_ws.RESTMessageV2('Get Data', 'Default GET');
var response = r.execute();
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
gs.print(responseBody);
gs.log("response body is" + responseBody);
var obj = JSON.parse(responseBody);
If i was able to solve your query, please mark my answer correct and helpful.
Thanks & Regards
Prasant kumar sahu
