How to print the out put using commas in background script
sekhar6
Hai all,
 I have a small doubt ,How to print the data using comma in the background script
out put is
sekhar
chandu
power
i want to print as
sekhar,chandu,power.
thank you
sekhar.
14 REPLIES 14
@sekhar6 Oh ok.
Then instead of current.u_specific_location =(arr.join(",")); you must write below
var parentGr = new GlideRecord('<PARENT TABLE NAME>');
if(parentGr.get(current.<PARENT IDENTIFYING FIELD>)){
parentGr.u_specific_location =(arr.join(","));
parentGr.update();
Please mark as correct answer if this solves your issue.
hai
can you tell me what is parent identifying field
please let me know
@sekhar6 On child table there must be some field which is referencing the parent table. The link between the child and parent table.
Raghav Sharma24
Giga Patron
Are you getting data from some table? it is usually printed with a contact operator "+";
example:
var num;
inc.addActiveQuery();
inc.query();
while(inc.next())
num = inc.number+","+num;
gs.print(num);
jaheerhattiwale
@sekhar6 Add values to an array like
var arr = ["sekhar","chandu","power"];
then print array
gs,print(arr.toString());
