how to restrict not moving to next state it should be in same state when my conditions not satisfy
Teja3
pls check below on change client script on problem table
when ever user select source as incident problem etc and under related list if no records associated then it should restrict not moving to assigned state and my code saving its moving to next state
// //Function to check associated records when state is in new
    var checks = g_form.getValue('state');
    g_form.addInfoMessage("check" + checks);
    if (checks == '1') //when state isnew
        var ga = new GlideAjax('CheckAssociatedRecords1');
        ga.addParam('sysparm_name', 'checkAssocaited1');
        ga.addParam('sys_id', g_form.getUniqueValue());
        ga.addParam('source', g_form.getValue('u_source'));
        ga.getXML(removePending);
        // Prevent form submission
function removePending(response) {
    if (answer == 'true') {
        var source = g_form.getValue('u_source');
        if (source == '0') //source is IT Incident
            g_form.addInfoMessage("Since the Source is selected as Incident, please associate Incident in the IT Incident list of the relevant tabs below");
        } else if (source == '1') //Source is Event
            g_form.addInfoMessage("Since the Source is selected as Event, please associate alert in the Alerts list of the relevant tabs below");
        } else if (source == '4') // Source is IT Problem
            g_form.addInfoMessage("Since the Source is selected as IT Problem, please associate problem  in the IT Problems list of the relevant tabs below");
        } else if (source == '8') //Source is IT Release
            g_form.addInfoMessage("Since the Source is selected as IT Release, please associate release in the ITPPM RM Release list of the relevant tabs below");
            //alert("Since the Source is selected as IT Release, please associate release in the ITPPM RM Release list of the relevant tabs below");
    if(answer!='true'){
        g_form.setValue('state','1');
below is script include
var CheckAssociatedRecords1 = Class.create();
CheckAssociatedRecords1.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    checkAssocaited1: function() {
        var rec = this.getParameter('sys_id');
        var src=this.getParameter('source');
        if (src== '0') //when source is IT incident
            var inc = new GlideRecord('itinc');
            inc.addQuery('problem', rec);
            inc.query();
            if (inc.getRowCount() < 1) {
                return true;
            //it_problem
        } else if (src== '1') // when source is Event
            var event = new GlideRecord('alert');
            event.addQuery('incident', rec);
            event.query();
            if (event.getRowCount() < 1) {
                return true;
        } else if (src== '4') // when source is IT problem
            var prb = new GlideRecord('problem');
            prb.addQuery('problem', rec);
            prb.query();
            if (prb.getRowCount() < 1) {
                return true;
        } else if (src== '8') // When source is IT Release
            var rel = new GlideRecord('ppm_rm_release');
            rel.addQuery('parent', rec);
            rel.query();
            if (rel.getRowCount() < 1) {
                return true;
    type: 'CheckAssociatedRecords1'
As you mentioned, the condition requires the state is "new" and assigned to "changes," so your Business Rule will only execute when this condition is met. This means the BR will only run if the previous state is "new" and the assigned_to field changes to a different value.
so once you reload the form and try to save the form without changing assigned_to in that case BR won't execute because condition didn't match.
Hope this help you.
Moin
Teja3
it should restrict not moving to next state the next state is assigned so if assigned to any user then it will move to assigned state so i used assigned to changes
how can i make it restrict
I'm still unclear about it. Could you please share a screenshot of the "When to run" section in the Business Rule?
