How To Reuse Client Side Script Code
David165
Mega Expert
Hi
I've written a short client script to change the colour of a selection value form field when the value changes. It works well, but I want to use the same code across quite a number of form fields. How can I put this code into a client side function that I can call for each of my form fields?
I looked at UI scripts, but my head exploded with the complexity of implementing these. Isn't there a simpler way to call a custom client side function?
Here's the onChange function I'd like to call for a variety of form fields:
	var elementID = g_form.getElement(control.name);
	switch(newValue) {
		case "3": elementID.style.backgroundColor = "red"; break;
		case "2": elementID.style.backgroundColor = "orange"; break;
		case "1": elementID.style.backgroundColor = "yellow"; break;
		default: elementID.style.backgroundColor = "white"; break; }
Thanks in advance.
David
David165
Mega Expert
Hi
I'm delighted to report that I have, at last, resolved this issue. After weeks of trying different methods to load the functions I wanted to share between fields on a form (so I could call the same functions onChange on several form fields) I could get it to work by including my shared functions within <script></script> tags inside a UI Macro:
<?xml version="1.0" encoding="utf-8" ?>
	<script>
		function calcgxpassessment() {
                  // My code here
	</script>
</j:jelly>
Within my code, I had to rework things like && and change double quotes because these are XML entities. I haven't tried replacing these with the correct XML entities (E.g replacing && with &amp;&amp;)
I then included the UI Macro in a UI Formatter
and then dropped the UI formatter into the bottom of the form.
Finally, I was able to call the function calcgxpassessment() onChange from any choice field that needs to recalculate the risk. I also had to remember to deselect "Isolate script" from these client scripts. Otherwise, they couldn't see the shared function.
My project is back on the rails ðŸ™‚
David
18 REPLIES 18
Yes, it's set to all on both the onLoad and onChange scripts.
I see plenty of other people with the same error when using this technique, but no solution to it. I did see one post that said this method doesn't work in the portal.
Another thread suggests you have to use a variable set, but I can't see the reasoning for this.
There are plenty of threads advocating your solution, but I haven't found any that flag the suggestion as a solution to the issue.
David
I still have the same issue in Orlando release.
I have unmarked the "Isolate Script" flag.
UI Type is set to all.
Checked for function name several time for any possible spelling mistake.
But still giving same error "onChange script error: ReferenceError: CalcutePropertyValues is not defined function () { [native code] }"
Did you get  the solution for the error?
Anton6
The solution is in this community thread: https://community.servicenow.com/community?id=community_question&sys_id=fe0090dddbd358d0fa192183ca96...
All credit go to Tony for this small change!
checkPrimaryRole = function() {
	alert('in the function');
Prateek kumar
Take a look at this blog. It has some nice scripts you can reuse
https://community.servicenow.com/community?id=community_article&sys_id=7eb34b9bdb2b5f848e7c2926ca961...
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
