How to set default filter for Add affected CIs popup window?
dianemiro
Hi Everyone,
We have a related list under Change Request called Affected CI then under this related list, we have add button. Upon clicking the Add button, a window will popup (see below). How can I set the value of the Configuration Class to always Configuration Item for all users then how can I set the default filter to Company is the same as the company under change request and how can I hide the breadcrumbs as well. Thank you in advance.
Diane
dianemiro
I was able to do this by modifying AssociateCItoTask script include by adding the following lines:
var gr_chg = new GlideRecord('change_request');
		if(gr_chg.get(chgReqId)){
		url.set("sysparm_query", 'install_status!=7^company=' + gr_chg.u_customer + '^ORnameLIKEgeneric');
Thanks everyone who helped! Marking this as closed.
Hi Diane,
This is an old thread but I'm taking my chances. I have exactly the same requirement from a client of ours. Can you share how you achieved this?
Many thanks!
