How to set fields auto populate using script include?
mahesh babu1
Hi
     I just created a scripted code from the server side as well as client side but i am enable to get output
i just given script as
On Client script:
Type : onchange
Field : caller
    var abc = g_form.getValue('caller_id');
    var ga = new GlideAjax('global.getdetails');
    ga.addParam('sysparm_user', 'getuserdetails');
    ga.addParam('server', abc);
    ga.getXML(pop);
    function pop(response) {
        var resp = (response.responseXML.documentElement.getAttribute('answer'));
        alert(resp);
        var result = resp.split(';');
        g_form.setValue('u_first_name', result[0]);
        g_form.setValue('u_last_name', result[1]);
        g_form.setValue('u_user_manager', result[2]);
On script include
Cient callable is checked
var getdetails = Class.create();
getdetails.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getuserdetails: function() {
        var y = this.parameter('server');
        gr.addQuery('sys_id', y);
        if (gr.next()) {
            return gr.u_first_name + ';' + gr.u_last_name + ';' + gr.u_user_manager;
    type: 'getdetails'
suvro
Hi Mahesh,
You can always go with the zero code way like below
https://community.servicenow.com/community?id=community_article&sys_id=3f0cf115db7fc190847d5ac2ca961931
