How to set Problem Priority based on Incident Priority (in Business Rule)
jas101
Hello everyone.
We have a business rule that creates a problem record automatically when a major incident record is resolved. Currently the business rule looks something like this:
var prob = new GlideRecord("problem");
prob.u_mi_reference = current.sys_id;
prob.short_description = current.short_description;
prob.description = current.description;
prob.cmdb_ci = current.cmdb_ci;
prob.u_category = current.category;
prob.priority = current.priority;
prob.u_source = 2;
However we are overhauling our Problem priorities so they will now be distinct from Incident priorities. Subsequently please can someone help tell me how I can set the new Problem priority based on the Incident one given that they are no longer matching? E.g. we will want the Problem record priority to be 'P1 - Critical' if the Incident has a priority of 'MI - P1' or 'MI - P2' or if the Incident is priority 'MI - P3' or 'MI - P4' then the Problem priority needs to be 'P2 - High'.
Many thanks in advance for any assistance.
Daniel
Kalaiarasan Pus
You can define an array that will hold the mapping of incident to problem priority mapping.
Ex
var problemPriority = [];
problemPriority[1]=1;
problemPriority[2]=1;
problemPriority[3]=2;
problemPriority[4]=2;
prob.priority = problemPriority[current.priority];
Note : Change the values as per your need.
Many thanks Kalai, this worked great.
Thank-you everyone else too for your speedy input.
