how to trigger a flow from flow designer using ui action script
Alon Grod
How can trigger a flow (from flow designer) ui UI Action Script ?
Tanushree Maiti
Hi @Alon Grod
Refer: https://developer.servicenow.com/dev.do#!/learn/learning-plans/australia/servicenow_application_deve...
https://developer.servicenow.com/dev.do#!/reference/api/zurich/server/ScriptableFlowAPI
https://www.servicenow.com/community/servicenow-ai-platform-forum/flow-triggered-from-another-flows-...
  var inputs = {};
        inputs['table_name'] = '<your_Table_Name>';
        inputs['current'] = current; // GlideRecord of table: incident
       sn_fd.FlowAPI.startFlow('global.[internal name of flow]', inputs);
        // Execute Synchronously: Run in foreground.
        sn_fd.FlowAPI.executeFlow('global.[internal name of flow]', inputs);
Ankur Bawiskar
@Alon Grod
the information you are looking for is easily available in docs or developer site
what did you try and where are you stuck?
Docs link below
FlowAPI - Scoped, Global
yashkamde
Hello @Alon Grod ,
To trigger a Flow using script, you must use a server-side script utilizing the built-in sn_fd.FlowAPI or sn_fd.Flow...
so rather than writing a script manually generate itself from your code :
Script will something like this :
(function() {
	try {
		var inputs = {
                   'current': current,
                   'table_name': current.getTableName()
		// Start Asynchronously: Uncomment to run in background.
		// sn_fd.FlowAPI.getRunner().flow('global.<flowname>').inBackground().withInputs(inputs).run();
		sn_fd.FlowAPI.getRunner().flow('global.<flowname>').inForeground().withInputs(inputs).run();
	} catch (ex) {
		var message = ex.getMessage();
		gs.error(message);
Then Use that block of code in your UI Action Script..
