How to update system set (using script)
Takumi_
Hi All.
I'm trying to update system set (sc_item_option)
I want to know that if you know something.
sample
// RITMNumber -> RITM + some number
// query table sc_item_option_mtom, get sc_item_option
var mtomGR = new GlideRecord('sc_item_option_mtom');
mtomGR.query();
var targetItemOptionSysID;
while (mtomGR.next()) {
if (mtomGR.getDisplayValue('request_item') == RITMNumber) {
targetItemOptionSysID = mtomGR.getValue('sc_item_option');
break;
var itemOptionGR = new GlideRecord('sc_item_option');
itemOptionGR.addQuery('sys_id', targetItemOptionSysID);
itemOptionGR.query();
while(itemOptionGR.next()){
if(itemOptionGR.getValue(value) == 'thisIsTarget'){
itemOptionGR.setValue('value', 'testValue');
itemOptionGR.update();
I'm not good at English.
You don't know what I said, Please ask me.
Abhit
Hi @Takumi_
Add a query condition, while you perform GlideRecord operation.
try the below code. this code will update the values where the values are "testValue" to test.
if you want to update any particular variables value to something then you have add a check condition in the GildeRecord of mtom table within the if loop under while loop.
var RITMNumber = 'RITM0010001'; // -> RITM + some number
//mtomGR.addEncodedQuery("request_item.numberSTARTSWITH"+RITMNumber); // Always add a filter to out the unwanted response.
mtomGR.query();
        updateOptionValue(targetItemOptionSysID);
function updateOptionValue(sysid) {
    itemOptionGR.addQuery('sys_id', sysid);
    while (itemOptionGR.next()) {
        if (itemOptionGR.getValue('value') == 'testValue') {
            itemOptionGR.setValue('value', 'test');
Cheers!!
Abhit
Takumi_
mtomGR.query();
itemOptionGR.addQuery('item_option_new', 'hostname_1'); // hostname_1 is question.
Just small change on itemOptionGR.addQuery('item_option_new', 'hostname_1');
mtomGR.query();
    itemOptionGR.addQuery('item_option_new.name', 'hostname_1'); // hostname_1 is question.
        if (itemOptionGR.getValue('value') == 'test123') {
            itemOptionGR.setValue('value', 'test1234');
