How to use and work with variable sets in flow designer
venkatrajesh
I have a two variable sets in catalog item. named Beforelive and Afterlive. in both variable sets L1 ,L2,L3 fields which are of type list collector
Now i need to create a catalog task for each value in L1 ,L2 and L3  and assigned to that particular group(value in L1,L2, L3).
Need this in flow designer
palanikumar
Variable Set variables can be accessed similar to the normal variables.
Use "Get Catalog Variables" action. This will get both catalog and variable set variables based on catalog item selected
Thank you,
Palani
those are readonly we can 't drag and drop, they are of type Object
