How to use DOM element within client script in UI Builder
‎08-26-2024 10:31 AM
I am trying to run the below code within client script in UI Builder.
function handler({
api,
event,
helpers,
imports
helpers.timing.setTimeout(function() {
var script = this.document.createElement('script');
script.src='https://cdnjs.cloudflare.com/ajax/libs/html2canvas/0.4.1/html2canvas.min.js';
script.onload = function() {
takeScreenshot();
this.document.head.appendChild(script);
function takeScreenshot() {
html2canvas(this.document.body, {
onrendered: function(canvas) {
var canvasVal = canvas.shadowRoot;
var dataURL = canvas.toDataURL("image/png");
var link = this.document.createElement("a");
link.href = dataURL;
link.download = "screenshot.png";
link.click();
}I see an error message stating "html2canvas is not a function" in the browser log. Thanks.
‎08-29-2024 01:46 AM
@Sheldon  Swift/ @Brad Tilton
Here is the updated code by accessing the shadow DOM.
if (typeof this.document !== 'undefined') {
script.src='https://cdnjs.cloudflare.com/ajax/libs/html2canvas/1.4.1/html2canvas.min.js';
console.log('html2canvas is loaded and ready to use.');
this.window.document.querySelector('macroponent-f51912f4c700201072b211d4d8c26010').shadowRoot.querySelector('sn-canvas-appshell-main').shadowRoot.querySelector('macroponent-c276387cc331101080d6d3658940ddd2').shadowRoot.querySelector('sn-canvas-main').shadowRoot.querySelector('sn-canvas-screen').shadowRoot.querySelector('macroponent-fba9fd6793430210ec8c32edfaba10f0').shadowRoot.querySelector('now-button').shadowRoot.querySelector('button').onclick = takeScreenshot();
link.click();
console.error('Document is undefined.');
});But i still see the html2canvas has an error and not code is not working on the UI Builder form. Can you please help!
‎08-29-2024 05:42 AM
We don't really support accessing the DOM from UI Builder. I think a custom component is your best bet here. Unfortunately, I don't have any step by step guides for this use case, but you can start here: https://developer.servicenow.com/dev.do#!/reference/next-experience/washingtondc/ui-framework/gettin...
‎08-29-2024 06:13 AM
Hi @Hari1 - The underlying issue is that html2canvas is loaded in the main document's DOM, while the button is located within a shadow DOM. This separation means that html2canvas is not defined in the context where your takeScreenshot() function is executed.
Also, there's no reason for any of that querySelector code. You can define what happens when the button is clicked in UI builder:
‎08-29-2024 10:02 AM
@Sheldon  Swift, Yes that is exactly what i am trying to do. I am calling the client script in the UI Builder from the Button Clicked event. Please refer the below snapshot.
Below is the client script that i am using in the UI Builder:
function handler({
api,
event,
helpers,
imports
takeScreenshot();
link.click();
And i see the error: html2canvas is not a function
Can you please help. Please let me know if i am doing anything wrong.
‎08-27-2024 06:40 AM
Hi @Hari1
I guess the error the version of html2canvas you are trying to load is quite old (0.4.1).
can you try the below :-
function handler({ api, event, helpers, imports }) {
helpers.timing.setTimeout(function () {
var script = document.createElement('script');
script.src='https://cdnjs.cloudflare.com/ajax/libs/html2canvas/1.4.1/html2canvas.min.js'; // Updated to a newer version
script.onload = function () {
takeScreenshot();
// Ensure html2canvas is loaded
if (typeof html2canvas === 'function') {
html2canvas(document.body).then(function (canvas) {
var link = document.createElement("a");
link.click();
}).catch(function (error) {
console.error('Screenshot capture failed:', error);
console.error('html2canvas failed to load or is not available.');
