how to use soap step in flow designer correctly
Lior grinberg1
Hi Friends,
I’m trying to call the ServiceNow Table SOAP API (incident / problem) from Flow Designer using the SOAP step, and I’m stuck.
What I’m trying to do
  • Use Flow Designer → SOAP step
  • Call incident.do SOAP API (get operation)
  • Then call problem.do SOAP API using the same credentials/instance
So, what I did is I first created a soap message
  • Created SOAP Message from WSDL named soap_incident:
    https://<instance>.service-now.com/incident.do?WSDL
  • Authentication type: Basic
  • SOAP Message Functions auto-generated:
    • get
    • getRecords
    • insert
    • update
    • delete, etc.
then in the flow I created a soap step
and the problem is:
  • The SOAP step returns HTTP 200
  • But the response body is HTML, not SOAP
  • The HTML looks like the ServiceNow UI / Guest page
If I'm changing the "Connection Alias" to this URL https://<instance>.service-now.com/incident.do?SOAP
it is working, but then I cannot call to another soap step with https://<instance>.service-now.com/problem.do?SOAP.
because I cannot create another Connection Alias with the same domain.
So, my question is what is the correct setup?
Thanks for anyone that tries to answer 🙂
Lior Grinberg
@Lior grinberg1 ,
Could you please give me the screenshot of the Connection Alias that you used from ( sys_alias ) table..
Sagnic
