i am not able to post Requested for field using the API explorer to the sctask table
chercm
i am using buy item ( post) , using catalog task API . it is getting a blank field on it . when the req is created
  "sysparm_quantity" :"1",
   "variables":{
      "requested_for" : "",
        "type_of_room_sqeep_00" : "",
        "time_of_room_sweep" : "",
        "building" : ",
       "select_location_00" : ",
      "business_justification" : ""
@Ankur Bawiskar i am getting if i am using the above script
  "error": {
    "message": "com.glide.rest.domain.ServiceException: Exception while reading request",
    "detail": ""
  "status": "failure"
var cart = new sn_sc.CartJS();
var item = { // Note that values using CartJS are instantiated via a JSON object
	'sysparm_id': '060f3afa3731300054b6a3549dbe5d3e',
	'sysparm_quantity': '1',
	'variables': {
		'requested_for': 'David Cher',
var cartVals = cart.addToCart(item); // The addToCart function returns a JSON object reflecting the status of the cart
var checkoutVals = cart.checkoutCart(); // The checkoutCart function returns a JSON object with info about the submitted cart, contents varying if two-step checkout is active
Sateesh Kumar D
Requested for is a field on request table, doesn't necessarily have to be a variable on maintain item until unless you created that variable. In above JSON body it looks like the requested for is assigned inside variable object.
chercm
@Ankur Bawiskar
do you mean to use this in the REST API explorer ?
var id = GlideGuid.generate(null); // Generate a new GUID
var cart = new Cart(id); // Instantiate a fresh cart
var RITM = cart.addItem('060f3afa3731300054b6a3549dbe5d3e');  // The value used here is the sys_id of our laptop catalog itemcart.setVariable(RITM,'ram','16');       /**/cart.setVariable(RITM,'os','win10');     /* Catalog item variables can be populated */
cart.setVariable(RITM,'storage','1tb');  /**/
var request = cart.placeOrder();  // The placeOrder() function returns a GlideRecord for the sc_request record it generates
