if condition not run in flow designer
Abinesh
facing an issue in flow designer.
Step 6 : look up records (used to get count of records)
Step 7 : if condition is placed. When count for step 6 is more than 0 then should be evaluated as True.
But in this instance, step 6 is completed but step 7 is not run. Anybody have an idea why this might have happened?
By changing logic to see if it resolves the issue, you are identifying the root cause. Reproducing it, adding logging, etc. this all helps to get to the root cause.
