Invalid object in scoped script while triggering flow through UI action
01-10-2025 03:41 AM
A error message is being displayed while we are trying to trigger a flow from an UI action. Not able to identify what is the issue since all the scripts in the flow are in the same scope.
Any reference to fix this issue. Thank You.
01-10-2025 03:50 AM
Did you check if that flow is active and published?
UI action and flow both are in same scope?
Did you copy the script from the Create code snippet feature from flow?
01-10-2025 05:27 AM
@Ankur Bawiskar Yes both are in same scope. Flow is active and published.
01-10-2025 06:51 AM
Is this happening when admin clicks or non-admin clicks?
Is this happening all the time?
01-10-2025 07:11 AM
Happening all the time.
02-03-2026 07:08 AM
Hi, please open your Flow and check the Flow Executions. The error message probably comes from one of your Flow Actions.
Even if both of your records are in the same scope, they might access a table or a script which is not in that scope. In this case you need to create a new Cross Scope Policy.
The execution might show you exactly where the error occurred:
