01-05-2026 07:11 PM
Jira Trigger Not Firing in Custom Flow, but OOB Jira Example Subflow Works
I’m facing an issue with Jira triggers in Flow Designer and would like some clarification.
I created a new flow with the trigger Jira → Issue Created / Issue Updated (no conditions).
However, this flow never triggers.
At the same time, the out-of-box Jira example subflow provided by the Jira Spoke:
Triggers correctly
Receives the Jira payload
Works as expected
Both flows:
Are in the Global scope
Use the same Jira connection
Since the example subflow is working, the Jira webhook, authentication, and connection are confirmed to be fine.
My questions:
Is there a known limitation where newly created Jira-triggered flows do not get registered to the webhook listener?
Is the recommended or required approach to clone/extend the OOB Jira example flow instead of creating a new flow from scratch?
Any guidance or best practices for extending Jira triggers in ServiceNow would be greatly appreciated.
Thanks in advance!
01-13-2026 04:23 AM
Step 1: Navigate to Jira Webhook Registries in ServiceNow.
Step 2: Add the Jira API token in the Token field.
Step 3: Click on Callback URL, copy the generated URL, and paste it while creating the webhook in Jira.
Step 4: In Flow Designer, duplicate the default Jira process flow available under Subflows (this flow is installed automatically when the Jira Spoke is installed). Configure the flow by adding all the required actions so that when a ticket is updated in Jira, the webhook triggers the flow and updates the corresponding incident in ServiceNow.
Step 5: Before testing the flow, add the newly created flow to the Jira Webhook Routing Policies and associate it with the webhook.
01-05-2026 07:21 PM
yes I believe newly created flows require some additional config.
the OOTB subflow works because it's already having a pre-defined config
Bi-directional Jira Webhook Setup
Jira Integration Hub Subflow Issue
01-13-2026 04:23 AM
