JSOn array flow designer, for each donsen't work
Melker
Kilo Expert
Hi
I try to get my JSON array output to work in the flow designer for each step.
But it just count 0 of 0
The output is from a Powershell script and run thru the JSON parser in the action step
The JSON Object array output:
    "root": {
        "root_array": [
                "ID": "1",
                "IDA": {
                    "CollectionID": "SMS00001",
                    "CollectionMemberCount": "270",
                    "CollectionName": "All Systems",
                    "CollectionType": "2"
                "ID": "12",
                "IDA": {
                    "CollectionID": "CHQ00016",
                    "CollectionMemberCount": "1",
                    "CollectionName": "TestU",
                    "CollectionType": "1"
How can i make the for each item loop to work?
( I'm new to ServiceNow so bare with me 🙂 )
If you click on your action in the flow execution details. Does it return the correct values like this under "runtime values"?
11 REPLIES 11
Had shorten this output in the step so my template didn't work.
To get everything correct, after creating it on the Parser, I save it as a template and then use that template to build the output structure. Did you remember to also map the data pill from the parser to the output variable?
Nevermind, saw that when you ran the action standalone, it works like it should.
Was something wrong in my template.
And I didn't see the difference between action and step output.
But now it works 🙂
Thanks for your help. It made me see where I had the issue
