Limit short description to max 40 characters for Projects and Demands
PaulaaO
Hi Community,
I have been asked to configure the fields that represent project and demand names so users would be restricted to setup names longer than 40 characters.
The field is short_description and it's a shared field from the extended tables (task for demand and planned_task for project) which means I cannot update the dictionary record.
I have created a Client Script and a Business Rule to try and drive the behaviour, however I am struggling to enforce it when I create the project from a template (link: To create project from a template click here.)
The Client Script (onChange) is as following (it's similar for Demand and for Project)
    if (newValue.length > 40) {
        alert(getMessage('Project name must be 40 characters or less.'));
        // Reset the field value to the previous value
        g_form.setValue('short_description', oldValue);
The Business Rule (before insert) is as following (only for Project)
	// check if Project name exceeds 40 characters
	if (current.short_description.length > 40) {
		current.setAbortAction (true);
		gs.addErrorMessage('Project name must be 40 characters or less');
})(current, previous);
What am I missing and what do I need to do to make this work?
Thank you.
Paula
Have you added any logs to see if the business rule executes ?
Can I see a screenshot of the business rule, conditions and when to run
Run this BR and see if you see anything in the logs
gs.log('(current.short_description.length=> ' + (current.short_description.length );
No, I haven't added logs (not too sure how I would do that). I'm more of a beginner with dev side of things, especially if it involves scripting.
Happy to take on any guidance
Here you are:
thanks Anurag, however nothing was picked up in the system logs.
May I check if the script line is correct, as I had an error?
Should it be:
gs.log('current.short_description.length=> ' + current.short_description.length);
or
gs.log('current.short_description.length=> ' + (current.short_description.length));
I've tried various versions but with no success
PaulaaO
I also came across 2 OOTB UI Macros - not sure if maybe these could be configured to incorporate the character limit restriction (or if it's advisable at all)..
I've had a go using Bard and Chatgpt, but with no success 😞
This is the OOTB version
<?xml version="1.0" encoding="utf-8"?>
<j:jelly xmlns:j="jelly:core" xmlns:g="glide" xmlns:j2="null" xmlns:g2="null" trim="false">
	<table width="350px">
		<j:if test="${sysparm_template_action != 'apply_template'}">
			<tr id="project_name">
				<td nowrap="true" data-type="label" class="label label_spacing">
					<label><span class="mandatory_populated label_description">*</span>${gs.getMessage('Project name')} </label>
				</td>
				<td nowrap="true" class="input_controls">
					<input name="project_name" placeholder="${gs.getMessage('Project name')}" autocomplete="off"/>
				</td>
			</tr>
		</j:if>
		<j:if test="${sysparm_has_children != 'true'}">
			<tr id="start_date">
				<label><span class="mandatory_populated label_description">*</span>${gs.getMessage('Start Date')} </label>
			</td>
			<td nowrap="true" class="input_controls test">
				<g:ui_date_time name="project_start_date" value="${jvar_start_date}"/>
			</td>
		</tr>
		</j:if>
		<tr id="project_template">
				<label><span class="mandatory_populated label_description">*</span>${gs.getMessage('Project template')} </label>
			</td>
				<g:ui_reference name="template_id" table="${sysparm_template_table}" value="${sysparm_template_id}" query="active=true^table=${sysparm_table_name}" displayvalue="${sysparm_template_name}" />
			</td>
		</tr>
		<tr id="dialog_buttons">
			<td align="right" colspan="2">
				<g:dialog_buttons_ok_cancel ok="return actionOK()" ok_id="ok_button" cancel_type="button"/>
			</td>
		</tr>
		<tr><td colspan="2"><br/></td></tr>
	</table>
</j:jelly>
