Load True/False data using Transform Maps
‎12-14-2016 09:48 AM
I have two true/false fields on my csv file that I loaded into the system as a data source. After I map the data correctly, I run the transform map and the True/False fields are not being populated. I looked online for scripts to help with this problem and I tried a few scripts but nothing works. On the csv file, the true/false fields are in CAPS. This is my script so far and it didn't work,
answer = (function transformEntry(source) {
if (u_business_associate_agreement.u_avmed_baa_ == "TRUE") {
answer = true;
if (u_business_associate_agreement.u_avmed_baa_ == "FALSE") {
answer = false;
})(source);
u_business_associate_agreement is the source table
u_avmed_baa_ is the field
Would I need answer = false to be pointed to the target table?
‎12-14-2016 11:55 AM
Yeah when I go to the import set after loading the records, before running the transform map it has both the true/false fields set as strings but when I try to change them to true/false fields the option isn't in the type. Boolean isn't in the type either. I think the problem is the system cannot convert the string into a boolean.
Matthew Strecker
‎12-14-2016 12:40 PM
sorry, replace the table name with source:
if (source.u_avmed_baa_ == "TRUE") {
return true;
if (source.u_avmed_baa_ == "FALSE") {
return false;
})(source);
‎12-14-2016 02:02 PM
if (source.u_non_avmed_baa_ == "TRUE") {
answer = true;
if (source.u_non_avmed_baa_== "FALSE") {
answer = false;
})(source);
Thank you for all the help but I finally got it to work. Above is the correct answer.
Matthew Strecker
