Metric Definition Script to capture Assigned to and Assigned Group
kannann_
Kilo Expert
Hello All,
I have a field value Metric Definition which captures Assigned to value. I would also like to capture the Assigned Group in the value field when the Assigned to field changes. How do I do that? Please suggest.
11 REPLIES 11
You might have to follow what was done here: Creation of Metric with Script Calculation ?
That worked.... Removed the whole code inside the if loop, added it to function and then checked.. It WORKS!!!!!
Thank you all for your help
