Multi Row Variable Sets not Showing in catalog item
ragz
I have a service catalog item and it contains some variables and variable sets .
All variables and single row variable sets are showing up on the service catalog item .
But Mutli row variable set is not showing up , I dont know what I am doing wrong .
Need you support ...
Mark Roethof
Hi there,
If you disable all Container variables within that Multi-Row Variable Set, is the Multi-Row Variable Set shown then? We had some similar issues too due to incorrect usage of containers with Multi-Row Variable Sets.
Kind regards,
Mark
LinkedIn
Community article list
12 REPLIES 12
I would suggest to disable all variables and keep multi row variable set active and then see if visible.
Then activate other variable's one by one.
Ashutosh
In fact i have disabled containers and it works!!. Marked as helpfull...
someone knows why cannot use containers in junction with multi-row variable set?
KR. Angel
colinthebigguns
I had the same problem. The container variables in the catalog item itself prevented the Multi-Row Variable set from showing, even with no container variables in the Multi-Row Variable Set.
