Multiple instances of flow triggers at a time , need help configuring queue
Varun Sharma
Hi Experts,
I've a common flow attached to multiple catalogue items for a complex requirement.
If multiple catalogue items are requested simultaneously , messes up the end result , i want only one flow instance should get triggered at a time and rest should remain in queue so they should not run in parallel but only in sequential manner.
Kindly assist, if you have any idea.
Varun Sharma
Hi Pushpanjali,
Thanks for responding. all the catalogue items for licensing purposes are interdependent thus need a common flow for check, i need to find some way to queue other instances of same flow. if you've any idea regarding that. it'll be great.
Varun Sharma
