Need help in ATF
kkesavan
Hello guys,
I have a label called "Gender" with 2 dropdowns, "Male" & "Female". Now I have multiple dropdown combos for the different fields, If I select Male, a set of fields will be displayed and If I Select Female, a set of fields will be displayed.
Can I achieve this in one single test? I wanted to create test steps for this; please help me out how can I achieve this in #ATF #servicenow
Sardash
@kkesavan -
You can achieve this with the help of Parameterized test . Please find below link for eg -
https://www.youtube.com/watch?v=RF-WnXONek8
Also if you are going to create separate Test scripts for mentioned conditions then use 'Field State Validation'  Step for visibility of fields
If my response helped, please mark it by selecting "Accept as Solution" and " Helpful."
