Need help in BR
nameisnani
Hi Team ,
Need help in the below requirment
Requirment -
whenever work notes are updated in SCTASK, the same notes are automatically copied to the corresponding RITM work notes.
while testing
So all the previous updates from Sctasks are reflected in RITM work notes
what was the mistake , what needs to be update
Ankur Bawiskar
@nameisnani
check this link on how it can be done and it helps in avoiding loop as well
Sync'ing RITM and SCTASK work notes \ additional comments  response from Sravani44
Ankur Bawiskar
@nameisnani
@Ankur Bawiskar  Got confused - could you please help me more
@nameisnani
your requirement is to sync comments on RITM and SC Task, for that only I shared the link.
did you check that link and implement?
It should work fine.
the issue you are facing is because it's going in loop and whatever comments you add on SC Task you are sending to RITM and again RITM BR is triggering and adding the same comments to SC Task again.
