‎11-01-2023 12:32 PM - edited ‎11-01-2023 12:52 PM
Hi, I have a business rule which runs on the task table when the particular task state based on the item is changed to closed complete. There is a field in that task 'current.request_item.configuration_item' which is referenced to computer system table. So when task is closed, need to update the field in that record. This is not getting updated.
var comp= current.request_item.configuration_item;
var cs= new GlideRecord('u_cmdb_ci_computersystem');
cs.addQuery('name', comp);
cs.query();
while (cs.next()) {
cs.setValue('install_status', 'Return');
cs.update();
})(current, previous);
@Ankur Bawiskar @Amit Gujarathi
‎11-01-2023 01:05 PM - edited ‎11-01-2023 01:07 PM
What's output of comp in the log, if its reference column then it must be sys_id of record from table [ [u_cmdb_ci_computersystem]
replaced the cs.addQuery('sys_id', comp);
cs.addQuery('sys_id', comp); // if comp value is sys_id then apply the query on column sys_id instead of name
cs.query();
while (cs.next()) {
cs.update();
‎11-01-2023 02:07 PM
So its returning sys_id , perfect ..also going inside the while loop ( as TEST1 printed in log ).
are you sure that , install_status which is Integer type select box with choice values, I checked the sys_choice table for this install_status, all values are numeric. Check the same and use the numeric value instead of 'Return'.
‎11-01-2023 12:51 PM
Hi @2022_ServiceNow ,
You are setting the "install_status" value as "Return" in while loop but not committing/updating that record.
cs.update();
‎11-01-2023 12:58 PM
@AshishKM I have updated it, still not working
cs.query();
while (cs.next()) {
cs.update();
‎11-01-2023 01:21 PM
After while loops, I have added logs for cs, and it's giving me the correct system name.
But in the logs before while loop,
gs.log(cs + comp + 'TEST'); it's returning [object GlideRecord] sys_id TEST
‎11-01-2023 01:36 PM
The above line is giving the sys_id value ? if yes then check if this sys_id belongs a record in table [ u_cmdb_ci_computersystem]
Share the screenshot of BR condition "When to run" tab and script part with log output.
