Need help in onchange client script
Shahida07
I have location filed in form.When I am changing the location field it should check if that location has group in cmn_location table.if it has a group then I should get popup message like do not submit request.How to do this.
I tried this but it is not working
    if (isLoading ) {
        var location = g_form.getDisplayValue('u_location');
        var gr=new GlideRecord('cmn_location');
        gr.addQuery('full_name',location);
alert(location);
        if(gr.next())
            alert('location');
            varGroup=gr.group;
            if(Group!='')
                spModal.alert('Selected Location has group .');
Maddysunil
@Shahida07
Please below updated code:
    var gr = new GlideRecord('cmn_location');
    gr.addQuery('full_name', location);
    if (gr.next()) {
        var Group = gr.group; // Corrected variable name
        if (Group !== '') { // Check if group is not empty
        alert('Selected Location has group.'); // Corrected alert message
Please Mark Correct if this solves your query and also mark 👍Helpful if you find my response worthy based on the impact.
Ademir Amaral1
Hi @Shahida07
Using Glide Record in the client script is not a good practice, try using a Script Include and then calling a GA in your client script:
var LocationUtils = Class.create();
LocationUtils.prototype = {
initialize: function() {
hasGroup: function(location) {
return gr.next() && gr.group != null;
type: 'LocationUtils'
if (isLoading) {
var location = g_form.getValue('u_location');
var ga = new GlideAjax('LocationUtils');
ga.addParam('sysparm_name', 'hasGroup');
ga.addParam('sysparm_location', location);
ga.getXML(onSuccess);
function onSuccess(response) {
if (answer == 'true') {
g_form.showFieldMsg('u_location', 'Selected location has group', 'error');
It is  not working.I tried this.
