Need help modifying ACL script to use system property for editable variables on sc_task
Pratiksha KC
Hi
We currently have an ACL where item names are hardcoded to make variables editable on the sc_task level. However, we now want to replace this hardcoding and use a system property (with either a comma-separated list or query) to determine which catalog items should have editable variables.
I tried the below script, but it’s not working as expected. Could anyone please help me modify or correct it?
Script-
(function() {
// Read comma-separated sys_ids of catalog items from property
var editableItems = gs.getProperty('glide.sc_task.editable_variables', '').split(',');
// Clean and normalize
editableItems = editableItems.map(function(x) { return x.trim(); }).filter(Boolean);
// Get current catalog item's sys_id from the sc_task record
var itemSysId = current.item ? current.item.toString() : '';
// Allow edit only if current item's sys_id is listed in the property
return editableItems.indexOf(itemSysId) !== -1;
System property-
Ankur Bawiskar
@Pratiksha KC
so none of the variables should be editable on catalog task form to any user for RITMs belonging to those Items?
If yes then 2 approaches
1) onLoad client script + display business rule on sc_task
Display BR
    // Add your code here
    var editableItems = gs.getProperty('glide.sc_task.editable_variables');
    if (editableItems) {
        var arr = editableItems.split(',');
        var currentItem = current.request_item.cat_item.sys_id;
        g_scratchpad.makeReadonly = !(arr.indexOf(currentItem) > -1); // I added not in the beginning
        g_scratchpad.makeReadonly = false;
})(current, previous);
Normal onLoad Client Script and not catalog client script:
function onLoad() {
    if (g_scratchpad.makeReadonly)
        g_form.setVariablesReadOnly(true);
OR
2) ACL -> I am not sure if this works fine, you are already using this.
If the 2nd approach doesn't work or it takes time, 1st approach will work for sure.
šŸ’” If my response helped, please mark it as correct āœ… and close the thread šŸ”’ā€” this helps future readers find the solution faster! šŸ™
Raghav Sharma24
Giga Patron
try below:
answer= false;
var currItem = current.request_item.cat_item.sys_id;
if(currItem.indexOf(editableItems)>-1)
answer true;
Hi @Raghav Sharma24
Tried this but not working.
Try this, I believe the if stetment checking indexOf need to be reversed:
answer= false;
if(editableItems.indexOf(currItem)>-1)
answer true;
@Raghav Sharma24 Thanks for the reply.
Still not working. Tried using both ways.
