ā11-04-2025 11:50 PM - edited ā11-05-2025 12:51 AM
Hi
We currently have an ACL where item names are hardcoded to make variables editable on the sc_task level. However, we now want to replace this hardcoding and use a system property (with either a comma-separated list or query) to determine which catalog items should have editable variables.
I tried the below script, but itās not working as expected. Could anyone please help me modify or correct it?
Script-
(function() {
// Read comma-separated sys_ids of catalog items from property
var editableItems = gs.getProperty('glide.sc_task.editable_variables', '').split(',');
// Clean and normalize
editableItems = editableItems.map(function(x) { return x.trim(); }).filter(Boolean);
// Get current catalog item's sys_id from the sc_task record
var itemSysId = current.item ? current.item.toString() : '';
// Allow edit only if current item's sys_id is listed in the property
return editableItems.indexOf(itemSysId) !== -1;
System property-
ā11-06-2025 01:04 AM - edited ā11-06-2025 01:18 AM
so none of the variables should be editable on catalog task form to any user for RITMs belonging to those Items?
If yes then 2 approaches
1) onLoad client script + display business rule on sc_task
Display BR
// Add your code here
var editableItems = gs.getProperty('glide.sc_task.editable_variables');
if (editableItems) {
var arr = editableItems.split(',');
var currentItem = current.request_item.cat_item.sys_id;
g_scratchpad.makeReadonly = !(arr.indexOf(currentItem) > -1); // I added not in the beginning
g_scratchpad.makeReadonly = false;
})(current, previous);
Normal onLoad Client Script and not catalog client script:
function onLoad() {
if (g_scratchpad.makeReadonly)
g_form.setVariablesReadOnly(true);
OR
2) ACL -> I am not sure if this works fine, you are already using this.
If the 2nd approach doesn't work or it takes time, 1st approach will work for sure.
š” If my response helped, please mark it as correct ā and close the thread šā this helps future readers find the solution faster! š
ā11-05-2025 02:33 AM
@Pratiksha KC use debug ACL, to see which ACL is conflicting.
I think script is fine, check the same code in background script.
Please mark the answer correct/helpful accordingly.
ā11-05-2025 10:55 PM
@Pratiksha KC Dd you try the same script in background script?
Try debugging the ACLs, script looks good. There could be a conflicting ACL.
ā11-06-2025 12:07 AM
I checked but there is no conflicting role , Can you please check the screenshots I pasted in the post is that correct for script ?
ā11-06-2025 12:30 AM
Try debug security role, i tried this script in my PDI as background script and it worked.
Its not about conflicting roles, its about conflicting ACLs. For example if there are 2 ACLs and one of them provides the access and other restricts , the access will be provided.
ā11-06-2025 12:51 AM
Also checked ACLs, there are no conflicting ACLs on sc_task.variable
