Need help on getting tickets not updated for 5 business days
shaik_irfan
we have a requirement where users who not updated incident assigned to them past 5 business days i want to send a notification to the assigned to & assingned to manager
For that i think i need to write a Scheudule job but can anyone please help me with the code to exclude the holidays & weekends ?
Below is the script which is working for 5 days but not for bsuiness days
gr.addEncodedQuery('active=true^sys_updated_onRELATIVELE@dayofweek@ago@3');
while(gr.next())
gs.eventQueue('my.event', current, gr.assigned_to, gr.assigned_to.manager);
Hi Shaik,
try this script below; you will have to iterate over all incident records
that could be a limitation
var incident = new GlideRecord('incident');
incident.addActiveQuery();
incident.query();
while(incident.next()){
var updatedTime = incident.sys_updated_on;
var days = 5;
var dur = new GlideDuration(60*60*24*days*1000);
// paste the sys_id of the 8*5 weekday schedule excluding holidays and weekends
var schedule = new GlideSchedule('090eecae0a0a0b260077e1dfa71da828');
var finalTime = schedule.add(updatedTime, dur,'');
var updatedGdt = new GlideDateTime(updatedTime);
var finalTimeGdt = new GlideDateTime(finalTime);
// if the date/time after adding 5 business days is greater than updated time
if(finalTimeGdt > updatedGdt){
12 REPLIES 12
Hi Shaik,
Any update on this?
Can you mark my answer as ✅ correct, 👍 helpful if you were able to achieve the requirement. This helps in removing this question from unanswered list and helps users to learn from your thread. Thanks in advance.
Hi Ankur,
I have a requirement to send notification if incident is created 1 day ago and not assigned to any body.
I used your above mentioned code however it is not running after the glide schedule part.
Can you please check and suggest if i am doing something incorrect.
var INC = new GlideRecord('incident');
INC.addEncodedQuery('active=true^assigned_toISEMPTY');
INC.query();
while(INC.next()){
var updatedTime = INC.opened_at;
var ID = INC.sys_id;
var days = 1;
gs.log('Pooja Schedule' + updatedTime + ID);
var schedule = new GlideSchedule('a60f9281dbbc6300c53e3caf9d961945');
Sri13
Hi @Ankur Bawiskar ,
I checked the above script and trying to replicate with Procurement Case.I have written a script include on global with accessibility from all scopes,however  receiving the following error.
Can't find method com.glide.schedules.Schedule.add(java.lang.String,com.glide.glideobject.GlideDuration,string). (sys_script_include.06b6a932977e69505b237886f053afe0.script; line 41) in:
getLastUpdatedindays: function() {
var pcrArr = [];
var pcGr = new GlideRecord('sn_spend_psd_procurement_request');
pcGr.addEncodedQuery('active=true^state=80');
pcGr.query();
while (pcGr.next()) {
gs.log('pcGr number '+pcGr.getValue('number'));
var updatedTime = pcGr.sys_updated_on;
gs.log('updatedTime '+updatedTime);
var days = 3;
var dur = new GlideDuration(60 * 60 * 24 * days * 1000);
var sched;
var grSchedule = new GlideRecord('cmn_schedule');
grSchedule.addQuery('name','08:30-17:30 Mon-Fri');
grSchedule.query();
while (grSchedule.next()) {
sched = new GlideSchedule();
sched.load(grSchedule.sys_id);
//var schedule = new GlideSchedule('dcc907c0db2c77005bcb24828a9619ad');
var finalTime = sched.add(updatedTime, dur);
if (finalTimeGdt > updatedGdt) {
pcrArr.push(pcGr.getValue('sys_id')+'');
return pcrArr.toString();
Please note, even by using the exact script that you posted here ,albeit different schedule sys_id  I am facing the same mentioned error.
Kindly note I need this for reporting.
Any responses on this would be highly appreciated.
Sri
