‎08-18-2020 04:18 AM
I have 2 fields(1. Reference Field & 2. Macro with Widget - Multi Line text) on the form which are depended on a drop down field(any one among the fields are displayed on the form). Multi Line text is a readOnly as its value is populated from the macro variable(Widget).
Now i need to add a validation step for the macro with Widget - multi line text variable to check whether Multi line text is empty or not.
Condition:
result[0] is true --- g_form.setDisplay('macro_widget', true);
g_form.setDisplay('multi_line_texts', true);
g_form.setDisplay('reference_field', false);
result[1] is true --- g_form.setDisplay('macro_widget', false);
g_form.setDisplay('multi_line_texts', false);
g_form.setDisplay('reference_field', true);
I have written an onSubmit script:
with the below script i am getting alert but request is getting submitted.
function onSubmit() {
// if (g_form.getValue('multi_line_text') == '') {
// alert('Please select something from the macro or go with the Reference Option');
// return false;
var ga = new GlideAjax('ToggleReferenceMacro');
ga.addParam('sysparm_name', 'setDisplayForRefOrMacro');
ga.addParam('sysparm_cat_item', g_form.getUniqueValue());
ga.addParam('sysparm_cat_item_env', g_form.getValue('environment_new'));
ga.getXML(setDisplayForRefOrMacro);
function setDisplayForRefOrMacro(response) {
var answer2 = response.responseXML.documentElement.getAttribute('answer');
var result = answer2.split(";");
var selectedEnt;
if (result[0] == 'true' && result[1] == 'false') {
if (g_form.getValue('multi_line_texts') == '') {
return false;
} else if (result[0] == 'false' && result[1] == 'true') {
if (g_form.getValue('reference_field') == '') {
alert('Please Select a value from refernce field');
return false;
} else if (result[0] == 'false' && result[1] == 'false') {
return true;
} else if (result[0] == 'true' && result[1] == 'true') {
return false;
} else if (g_form.getValue('reference_field') == '') {
return false;
Thanks.
Scripting and Coding
‎08-18-2020 06:26 AM
By this below script i have solved the issue..
if (g_form.getValue('multi_line_text') == '' && g_form.getValue('reference') == '') {
return false;
i was doing too many thing which were of no use.
Thanks.
return false;
Thanks.
‎08-18-2020 06:53 AM
So did you keep the Macro variable?
‎08-18-2020 07:40 AM
Yes
‎08-18-2020 04:40 AM
Hi instead of this create a checkbox type variable & call the script include onChange & on the basis of return result make it true/false.
Check the checkbox variable onSubmit validation & show appropriate message as with onSubmit script include call it cause the issue.
Or other option is to use getXmlWait()
Sudhanshu
