Need Help Returning Values with GlideAjax
codechaser
Giga Expert
I need to populate a dropdown of courses, based-on the term selected. I have a GlideAjax call to fetch the data and then use the addOption() function to populate the value in the 'u_course' field.   However, I am unable to filer courses offered by 'u_term_code'... The same list of courses is populated, regardless of term selected.
What am I missing?
Client Script:
var ga = new GlideAjax('GetListValue');
ga.addParam('sysparm_name','getList');
ga.addParam('sysparm_term ', newValue);
ga.getXML(fillDetails);
function fillDetails(serverResponse){
var answer = serverResponse.responseXML.documentElement.getAttribute("answer");
var choiceval = answer.split(',');
for(var i = 0; choiceval.length > i ; i++){
g_form.addOption('u_course', choiceval[i], choiceval[i], [i]);
Client Callable Script Include:
var GetListValue = Class.create();
GetListValue.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getList : function() {
var courses = [];
var gr = new GlideRecord('u_bsu_courses');
gr.addQuery('u_term_code', this.getParameter('sysparm_term'));
while(gr.next())
courses.push(gr.name.toString());
return courses;
type: 'GetListValue'
12 REPLIES 12
Ok, so the line should read: ga.addParam('sysparm_term ', g_form.getValue('u_term_code'));
and this is an onChange, so you're testing by changing the Term Code?
In the script includes, add:
var term = this.getParameter(''sysparm_term');
gs.log('Term is ='+ term);
does it return the correct value?
Put a gs.log after the while in the script includes - what's being returned?
and BTW - you're Course field isn't dependent on Term field, correct? It's just a choice field with choices.
Sorry for the confusion, but just want to double-check putting a gs.log after var term = this.getParameter('sysparm_term'); and after while on the script include, correct?   Course field is not dependent on Term, but guessing it should be if we are trying to refine our results, based-on the term courses are offered in?
Yes on the gs.log lines.
Making Course dependent on Term would probably forgo all of this code!
I agree 100% Michael!   However, when I right-click the field label to configure dictionary, there is no place to add a dependent field.   Is there another setting somewhere, perhaps I am missing?
