Need help to copy attachment from Child case to Parent case
VShine
Mega Guru
Hello Experts,
We have special use case where we have Parent & child case stored in same HR table.
I need to copy attachment from child case (hr performance case table) to parent case (on HR performance case table).
I see multiple community posts where copy from one table to another. But I couldn't find help on copying attachment from one record to another on same table.
Hi @vikrami
You have to apply the logic such a way that this BR should run only once so it will copy once.
Question, When do you want to copy attachment ? which event ?
@Ankur Bawiskar  and @rahulpandey -I tried both of the code & getting same response.  If I am keeping BR on Insert, attachment is not getting copied from child HR case to parent at all. If I am choosing it on update, attachment getting copied twice to the parent case.
Here is my business rule:
During copy you try deleting the older ones.
GlideSysAttachment.copy() would copy all the attachments again
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Hi @vikrami
VShine
Mega Guru
@rahulpandey and @Ankur Bawiskar - thank you so much....Was able to make it work by adding filter condition on When to run.
