‎02-16-2017 05:23 AM
I am attempting to populate a field fields on a table using GlideAggregate. I have successfully managed to populate 1 field, but am not looking to populate others. The idea here is to find all users with a specific department number and then count the amount of incidents open/closed/etc... Here is what I have to calculate closed yesterday. I am only using 1 specific user right now for testing.
var usr = new GlideRecord('sys_user');
usr.addQuery('sys_id', '0a9e1a1a4fc89e00c0cba3928110c7a8');
usr.query();
var person = usr.sys_id;
while (usr.next()){
var inc = new GlideAggregate('incident');
inc.addQuery('closed_at', '>=', gs.beginningOfYesterday());
inc.addQuery('closed_at', '<', gs.beginningOfToday());
inc.addQuery('assigned_to', person);
inc.addAggregate('COUNT');
inc.query();
var num = 0;
if(inc.next()){
num = inc.getAggregate('COUNT');
var stats = new GlideRecord('u_stats');
stats.addQuery('u_analyst.sys_id', person);
stats.query();
if (stats.next()){
stats.u_closed_yesterday = num;
stats.update();
I want to also count open incidents and put that in the field u_open on the stats table. So what I need help with, is how do I cleanly pass the variable 'person' to a new function and run an aggregate? For instance, if this is the script to count open incidents, I just want to set the 'person' query as global and use it in multiple functions.
var inc = new GlideAggregate('incident'); | |
inc.addQuery('state', 'IN', '1,10,11,12,20'); | |
inc.addQuery('assigned_to', person); | |
inc.addAggregate('COUNT'); | |
inc.query(); |
var open = 0; |
if(inc.next()){ | |
open = inc.getAggregate('COUNT'); |
var stats = new GlideRecord('u_stats'); | |
stats.addQuery('u_analyst.sys_id', person); | |
stats.query(); |
if (stats.next()){ | |||
stats.u_open = open; | |||
stats.update(); | |||
Hopefully my question makes sense. If not, I will do my best to explain it better. Thanks for all help in advance!
‎02-16-2017 10:29 AM
Hi Robert,
Thanks for the clarification. To find all users in a specific department...
// Get all users with that department...
var user = new GlideRecord('sys_user');
user.addQuery('department.name', '2112');
user.query();
while (user.next()) {
// call your function here, passing the user's sys_id
function2(user.getValue('sys_id'));
Does that help?
‎02-16-2017 10:52 AM
I was referencing 'function2' from above to do the counting and saving.
‎02-16-2017 10:59 AM
Ok, got it I believe! I will work on this a bit more and let you know. Thanks again!
‎02-16-2017 02:28 PM
I have it working now. Thank you sir!
‎02-17-2017 05:21 AM
Glad to hear you go it working. Thanks for using the community!
