Need help with Date Validation script
nicolemccray
I need an 'OnChange' script that will check to see whether the entered 'start_date' that is less than 2 weeks from today (or whatever day they are filling out the form).   If they enter a date less than 2 weeks away, I want to display a pop up message and prevent them from submitting the form.
chirag_bagdai
Hi Nicole,
If you don't want to do ajax calls each time, you can use JavaScript validation in onChange client script and onSubmit script :
var date1 = new Date(g_form.getValue('start_date');
var date2 = new Date();
var timeDiff = Math.abs(date2.getTime() - date1.getTime());
var diffDays = Math.ceil(timeDiff / (1000 * 3600 * 24));
if(diffDays >= 14) {
      alert("Error Message");
      return false;
else
        return true;
Chirag Bagdai
34 REPLIES 34
I've copied and pasted Script Include and Client Script exactly As-Is, and still no message displays.
Interesting
Please try to debug the script by adding log or please check below conditions :
Getting new Date value   ?
Does Script include have client callable checked ?
What result are you getting while using GlideAjax ?
Here is the error I see when debugging:
Changing the Client Script fixed the issue:
  //onChange Client Script
  if(newValue != '') {
  var ga_date_validation = new GlideAjax('StartDateValidation');
  ga_date_validation.addParam('sysparm_name','validateDateStartDate');
  ga_date_validation.addParam('sysparm_start_date', newValue);
  ga_date_validation.getXML(startDateValidationResponse);
function startDateValidationResponse(response) {
  if(answer == "false") {
  g_form.setValue('start_date','');
  alert("You've entered a start date less than two weeks prior to the Start Date of the course. We cannot support all of the logistical requirements to ensure a successful delivery for this course.");
Glad to know that the issue is fixed
