need help with isinSchedule()
sk87
Hi Guys,
So I've been introduced to Schedules and have been working on it for last couple of days.
Here's the code am trying to run in a scheduled job that would submit a catalog item if the date in in schedule '8-5 weekdays excluding holidays'. Each time I pass a weekday or any day for that matter, it goes in the else clause. Any thoughts?
var schedRec = new GlideRecord('cmn_schedule');       // Query table for schedule
schedRec.get('name','8-5 weekdays excluding holidays');// Get the schedule name
var sched = new GlideSchedule(schedRec.sys_id);       // Create variable schedule
var schedTime = new GlideDateTime("09-14-2017 08:30:00");             // Create variable with current date/time
if (sched.isInSchedule(schedTime))
      gs.log('In schedule');
else
      gs.log('not in schedule');
From what I have understood, here the date passed is a weekday and hence should print 'In schedule' in the logs. But its not. Kindly advise.
16 REPLIES 16
inbox me @:   hvrdhn88@gmail.com
Michael Kaufman
Giga Guru
For future adventurers, here is a script I use to help test schedules:
//Background Script - Schedule Test
(function() {
var schedule = new GlideSchedule('5afd4fae4fe92b00a2c3d0af0310c7f7');//Put Your Schedule sys_id here
gs.print('Schedule Name: '+schedule.getName());
gs.print('Valid Schedule: '+schedule.isValid()); //If this says false, your schedule isn't valid
var d = new GlideDateTime();
d.setDisplayValue("12-25-2018 08:30:00");
if(schedule.isInSchedule(d)){
gs.print('In Schedule: '+d);
else {
gs.print('Outside Schedule: '+d);
Thanks for sharing Mike!
Hey,
I'm getting false value in schedule.isValid(), do you know why ?
(function() {
var schedule = new GlideSchedule('55ebbbf15f002000b12e3572f2b47714');//Put Your Schedule sys_id here
else {
Jim Coyne
Did you find a solution to your issue?  If yes, please remember to tag the correct answer and any that were helpful.
