Need Help with Processing Script for RITM Cancel UI Page
Brett14
Giga Expert
All,
I have a requirement to add a cancel UI Action button to the RITM form that will open a window so that users can input cancel comments/reasons.   Which I created and it works except for the Processing Script section of the UI Page.
I need the Processing Script to change the state & stage fields of the RITM and update the form.   Which doesn't work at the moment.   I have pasted my UI Page code below:
Any suggestions will help out.   I haven't had to create many UI Pages within ServiceNow so I am a little stuck...
UI Page
HTML Section:
Client Script Section:
Processing Script Section:
Brett14
Giga Expert
Adding Script Include for anyone that runs past this post
Scrip Include:
Make sure you mark client callable
var cancelComments = Class.create();
cancelComments.prototype = Object.extendsObject(AbstractAjaxProcessor, {
cancelRITMComments: function(){
  var sc_req_item_sys_id = this.getParameter('sysparm_sys_id');
  var close_comments = this.getParameter('sysparm_close_comments');
  var gr = new GlideRecord("sc_req_item");
  if (gr.get(sc_req_item_sys_id)) {
  gr.state = 4;
  gr.close_notes = close_comments;
  gr.stage = 'Request Cancelled';
  gr.update();
  return true;
  _privateFunction: function(){ // this function is not client callable
UI Page Client Script (update):
function validateComments() {
  //This script is called when the user clicks "OK" in the dialog window
  //Make sure there are comments to submit
  var comments = gel("dialog_comments").value;
  comments = trim(comments);
  if (comments == "") {
  //If comments are empty, alert the user and stop submission
  alert("Please enter your comments before submitting.");
  return false;
  var ritm_sys_id = gel("sc_req_item_sys_id").value;
  var ajaxHelper = new GlideAjax('cancelComments');
  ajaxHelper.addParam('sysparm_name', 'cancelRITMComments');
  ajaxHelper.addParam('sysparm_sys_id', ritm_sys_id);
  ajaxHelper.addParam('sysparm_close_comments', comments);
  ajaxHelper.getXMLAnswer(function(){
  GlideDialogWindow.get().destroy();
HTML Section of UI Page (update):
<g:evaluate var="jvar_ritm_sys_id" expression="RP.getWindowProperties().get('sys_id')" />
<input type="hidden" name="sc_req_item_sys_id" id="sc_req_item_sys_id" value="${jvar_ritm_sys_id}"/>
<input type="hidden" name="selection_result" id="selection_result" value=""/>
Hi Chuck,
I had to create a script include and then call it from the Client Script Section of the UI Page.   I was able to get things working once I did that.
Thanks for your replies and suggestions.
Brett14
Giga Expert
Scrip Include:
  gr.state = 4;
  gr.update();
  return true;
  return false;
