Need to see two columns in reference variable and documented attribute is not working
Kirsten2
I have a catalog with a drop down for hardware name and I want the cost to appear next to that. My custom table is the reference table and 'cost' is a field for each record. Name is the main display.
The attributes I added are: re_auto_completer=AJAXTableCompleter;ref_ac_columns=u_cost;ref_ac_columns_search=true
When I fill out the catalog item the dropdown still only shows name.
 Any help is appreciated.
2 ACCEPTED SOLUTIONS
Chaitanya ILCR
Giga Patron
Hi @Kirsten2 ,
you have to use comma (,) instead of semicolon(;) in the variable attributes
try putting this in the variable attributes
ref_auto_completer=AJAXTableCompleter,ref_ac_columns=u_cost,ref_ac_columns_search=true
Chaitanya
Bhuvan
Giga Patron
@Kirsten2
There is a typo in the variable attributes, it must be 'ref' and comma instead of semicolon
Update the variable, save the record and try again. If it does not work, clear the cache or try from Incognito or InPrivate window of your browser.
Below is reference post,
https://www.servicenow.com/community/servicenow-ai-platform-forum/how-to-get-two-columns-to-display-...
If this helped to answer your query, please mark it helpful & accept the solution.
Bhuvan
kaushal_snow
Hi @Kirsten2 ,
Even if you have configured ref_ac_columns, the dropdown will show only the primary Display field as true. Showing multiple fields once selected requires additional workarounds...
1. Use a Lookup Select Box instead of a Reference variable. With this, you can set multiple fields in the Lookup label fields, giving you more control over displayed values.
or Add a Custom Display Field: Create a new field (e.g. abc_field in your reference table. Populate it with a combination of Name and Cost, for example via business rule or transform logic. Set that field as the Display field so both values appear once selected....
If you found my response helpful, please mark it as ‘Accept as Solution’ and ‘Helpful’. This helps other community members find the right answer more easily and supports the community.
Thanks and Regards,
Kaushal Kumar Jha - ServiceNow Technical Consultant/Developer
In the same list if you want one side name should come and another column cost then, you need to change your code to :
I have replaced semi colon with comma..
Thanks and Regards,
Ankur Bawiskar
@Kirsten2
answer is already shared by @Chaitanya ILCR as 1st response.
Try that and share the feedback.
