Need to split check boxes in to two columns in record producer
rog
Giga Contributor
I have a requirement where in I need to split 11 check boxes in a single variable set in to two columns. Could any one please suggest how to achieve this.
Thanks in advance.
Brent Sutton
Hi Rog,
Set your variable set "Layout" to "2 columns Wide" - you can choose if you want them alternating or onside, then the other. You then need to add the variables that you want to alternate into two separate containers with defined ends (required if your item is viewed on Service Portal otherwise you can use a single container with a split). Should look something like the following:
Let me know if this worked for you
Brent
Hi Rog,
Can you please answer a couple of questions so I can help troubleshoot your issue.
  1. Are you viewing the catalog item in platform or on the Service Portal?
  2. Can you please post a screenshot of your variable layout (similar to what I posted but include the "order" column).
  3. Check the order of your variables to ensure they are enclosed within the container.
Brent
P.S. If my suggestion helped then please mark as helpful and/or correct so other community members can benefit from this information.
Brent Sutton
Hi Rog,
Did you manage to find a solution to your question? Would be good to get this thread closed down.
Brent
