Not able to print value in log using script include
suprakash
Giga Expert
Not able to display value from script include
Please let me know what is wrong with the below code
I tried in background script with gs.print it worked
var HelloWorld = Class.create();
HelloWorld.prototype = Object.extendsObject(AbstractAjaxProcessor, {
helloWorld:function() {
var user_sysid = this.getParameter('sysparm_user_name');
gs.addErrorMessage( user_sysid); ----------------------- working
var getRecord = new GlideRecord('sys_user');
getRecord.query('sys_id',user_sysid);
getRecord.next();
var printvalue= getRecord.user_name;
gs.addErrorMessage(printvalue);    ------------ not working
gs.log("print value "+printvalue);     -------------- not working
return printvalue;
Ajaykumar1
Hi Suprakash,
Try adding if condition like below :
if(getRecord.next()){
return printvalue;
Ajay
The problem is solved, there was a minor but very bad mistake, it working now
Shubham Kakade
Giga Guru
Hello Suprakash,
getRecord.next();
The above line is an iterating function. You need to use an IF condition or while loop to iterate to next value.
Eg.
// add your error message
Thank you.
Shubham
