Notification when problem task assigned to my group
JulietD
Mega Guru
if a Problem Task is assigned to my group, I would like the system to send all group members an email notification.
I created a notification below,
Reported by: ${sys_created_by}
Number: ${number}
Assignment group: ${assignment_group}
Assigned to: ${assigned_to}
Priority: ${priority}
Short Description
Created Date(Don't include time): ${mail_script:date_without_time}
Not able to find a field for short description and created date without time. Can anyone help to solve this?
Preview mail:
Thank you
James Chun
Hi @JulietD,
There is a field called short_description on the Problem Task record which you can use.
And, you can use the following email script to get the created date without time.
(function runMailScript(/* GlideRecord */ current, /* TemplatePrinter */ template,
          /* Optional EmailOutbound */ email, /* Optional GlideRecord */ email_action,
          /* Optional GlideRecord */ event) {
		var gdt = new GlideDateTime(current.getValue('sys_created_on'));
		var date  = gdt.getDate();
		template.print(date);
})(current, template, email, email_action, event);
Email notification:
Number: ${number}
Short Description: ${short_description}
Outcome:
Cheers
SN_Learn
Mega Patron
Hi @JulietD ,
You can create a 'notification email script' and call it in the notification body with the below syntax:
${mail_script:notificationEmailScriptName}
Navigate to table [sys_script_email] and create new record with below details:
Name - problem_info
Script -
        template.print("<p>Hi, ");
		template.print("<p>Reported By: "+  current.sys_created_by);
		template.print("<p>Number: "+ current.number);
		template.print("Assignment group: "+ current.assignment_group.getDisplayValue());
		template.print("Assigned to: "+ current.assigned_to.name);
		template.print("Priority: "+ current.priority.getDisplayValue());
		template.print("Short Description: "+ current.short_description);
		var gdOpenedDate = new GlidedateTime(current.sys_created_on);
		var dateVal = gdOpenedDate.getDate();
		template.print("Opened Date: "+ dateVal);
In the email notification: Remove the content and add the below :
${mail_script:problem_info}
 This will give you flexibility to amend the content of notification in future.
