On change client script issue for reference variable
RudhraKAM
We have a table (cmdb_ci_appl)  where there is no Display value.
we have a catalog item in which we have a reference field, on selecting the 1st field we need to populate the 3 other fields.
How to set the app ID ( which is highlighted) upon selecting? ( as of now it is defaulting to name , which is on the left side)
Below is the Onchange CS script ( for some reason when the ID is selected it is not setting the name in the name field (name is of string type on the table )
    var AppID = g_form.getReference('citrix_application_id', SetApplicationvariables);
    function SetApplicationvariables(AppID) {
        g_form.setValue('citrix_application_name', AppID.name);
        g_form.setValue('citrix_application_version', AppID.version);
        g_form.setValue('citrix_application_vendor_name', AppID.u_common_name);
12 REPLIES 12
Hitoshi Ozawa
Hi RudhraKAM
Screen image is missing from the question. It is no longer possible to paste a image. It is necessary to save the image to a file in local pc and then upload the file.
Anyways, as others have already replied, I have been able to run the script and the fields were filled (except for citrix_application_vendor_name which is a custom field). Not sure why it's not working in your instance without further details.
As stated in the question, there is no display=true field in table cmdb_ci_appl.
I've defined variables as below.
Executed the form. Selecting item in citrix_application_id field filled other fields.
If using the single-line text variable it is working but the requirement is for the application name should be reference field. and the name is not populating ( the variable is mandatory ) on change it is setting to something but it is not displaying , i say this because mandatory is off  on change.
Field "Name" is a String in table cmdb_ci_appl
