Onchange client script validation for String variable
Mrman
I am trying to validate a String variable to check it has only Letters and does not contain numbers and it should be in below format having 13 letters
Could you help me with the Onchange Script for alpha numeric  , I tried below but not working .
Also I am not sure how to validate the format I mentioned above .Please suggest .
@ramamr
try either of the RegEx as per your requirement
Also no need of checking the length; the regular expression will handle this
    // this will allow lower and upper case
    var pattern =  /^([A-Za-z]{7})+([\s]{1})+([A-Za-z]{3})+((-[A-Za-z]){1})+([\s]{1})+([A-Za-z]{2})$/;
    // OR
	// this will only allow upper case
	//var pattern = /^([A-Z]{7})+([\s]{1})+([A-Z]{3})+((-[A-Z]){1})+([\s]{1})+([A-Z]{2})$/;
    if (!pattern.test(newValue)){
      g_form.clearValue('u_employment_registration_book_ctps');
      g_form.showFieldMsg('u_employment_registration_book_ctps', 'Enter a valid CTPS ID ', 'error', true);
Hi Ram,
I have tried the same expression in my code and it is not accepting the string you have added. As shown in below screenshot.
Below is my code in client script. Which is checking the expression in format XXXXXXX XXX-X XX. Please modify the code little in the regular expression and then it should work fine.
    var regx = /([A-Z]{7})+([\s]{1})+([A-Z]{3})+((-[A-Z]){1})+([\s]{1})+([A-Z]{2})/;
    if (g_form.getValue('short_description').match(regx)) {
        alert('mathcing');
        alert('Not matching');
        g_form.clearValue('short_description');
Mohit Kaushik
ServiceNow MVP (2023-2025)
