Order guide - dynamic rule base for client software distribution
Jesper Slot
In my company we use the Client Software Distribution integration with SCCM. We don't like how it appears on the portal - we got 100+ software items so you get a really long list, where you have to click "show more" xx number of times to see it all.
I'd like build an Order guide for this instead. My idea was to let the user select the software on the first page of the order guide and then fill in the related catalog item for the specified software on the next page.
I've build an order guide with a variable of the type "Lookup Select Box" for table: "sn_client_sf_dist_cat_item" - which is where the software items are located (the sc_cat_item table would also work, with some filtering). This seems to work fine when there are rule bases for it, but the problem is that I would need a rule base for each piece of software on the list, and this number grows all the time. We got another team for handling/creating the software items and they do not have access to modifying the order guide and I'd prefer them not to have, so ideally I was thinking there must be a way around this with a script.
I've discovered that the order guide takes the script code:
guide.add("sys_id of catalog item");
So adding this line will force the order guide to include the specified catalog item.
But here I lack some coding skills.. Can I combine this with the input from my variable?
I've tried with numerous variations of:
guide.add("current.variables.variable");
but it doesn't work. I cannot fetch the variables from the Order Guide - and even if I could, the script field on Order Guides is running server side. So how do I pull the the value of the variable and insert into the guide.add(); ?
Andrew Albury-D
Giga Guru
Hey Jesper,
I've had a read through you problem and before we start digging in to code and hacky solutions, have you taken a step back and considered that swapping a list of 100+ items for a single item with a list of 100+ options in a Lookup Select Box may not be the quick fix you are after?
Are there any other options to increase the usability of your catalog items rather than the solution proposed?
Have you considered:
  • Pushing a Search-first approach to your catalog items / software? Make sure the Meta tags are accurate and users shouldn't need to look through a list of software
  • Make a Dynamic Category based on the most requested items? Surely there would be 5 - 10 or so software items that get requested more than anything else, so using the 80/20 rule you could capture most cases with a quick sort, and for the edge cases push to search
  • Create a useful and meaningful category tree? If you look at the items and think about how they could be categorised (e.g. Development Tools, Productivity Tools, etc) you may be able to come up with almost a decision tree in categories that each item could be placed in to make them easier to find.
There are always many ways to solve problems, and often the "let's fix it with code" response isn't going to get you the best outcome, and it adds maintenance issues of it's own.
I hope this helps,
Andrew
20 REPLIES 20
Sriramachandra
(function checkContractEndDates() {
var reqGR = new GlideRecord('sc_request');
reqGR.addQuery('cat_item.name', 'New Hire Onboarding Request');
reqGR.query();
gs.info('Contract Expiry Check Started');
while (reqGR.next()) {
gs.info('Processing Request: ' + reqGR.number);
var contractEndDate = getVariableValue(reqGR, 'contract_end_date');
var manager = getVariableValue(reqGR, 'direct_report');
if (!contractEndDate || !manager) {
gs.info('Missing contract_end_date or direct_report. Skipping REQ: ' + reqGR.number);
continue;
gs.info('Found Contract End Date: ' + contractEndDate + ' | Manager: ' + manager);
var now = new GlideDate();
var end = new GlideDate(contractEndDate);
var diffDays = gs.dateDiff(now.getDisplayValue(), end.getDisplayValue(), true);
gs.info('Days until contract ends: ' + diffDays);
if (diffDays <= 14 && !notificationAlreadySent(reqGR.sys_id, '14_day')) {
gs.info('Sending 14-day notification for REQ: ' + reqGR.number);
sendEmail(manager, contractEndDate, '14_day');
logNotification(reqGR.sys_id, contractEndDate, '14_day');
if (diffDays <= 7 && diffDays >= 0 && !notificationAlreadySentToday(reqGR.sys_id, '7_day_daily')) {
gs.info('Sending 7-day daily notification for REQ: ' + reqGR.number);
sendEmail(manager, contractEndDate, '7_day_daily');
logNotification(reqGR.sys_id, contractEndDate, '7_day_daily');
gs.info('Contract Expiry Check Completed');
function getVariableValue(request, variableName) {
var ritm = new GlideRecord('sc_req_item');
ritm.addQuery('request', request.sys_id);
ritm.query();
if (ritm.next()) {
var opt = new GlideRecord('sc_item_option_mtom');
opt.addQuery('request_item', ritm.sys_id);
opt.query();
while (opt.next()) {
var def = opt.item_option_new.getRefRecord();
if (def.name == variableName) {
return opt.value;
return null;
function sendEmail(managerId, endDate, type) {
var userGR = new GlideRecord('sys_user');
if (userGR.get(managerId)) {
gs.eventQueue('custom.contract.expiry', userGR, endDate, type);
gs.info('Notification event queued for: ' + userGR.name + ' | Type: ' + type);
gs.info('Could not find user record for direct_report: ' + managerId);
function logNotification(reqId, endDate, type) {
var log = new GlideRecord('u_contract_notification_log');
log.initialize();
log.u_request = reqId;
log.u_contract_end_date = endDate;
log.u_notification_type = type;
log.u_sent_on = gs.nowDateTime();
log.insert();
gs.info('Notification logged: ' + type + ' for request ID: ' + reqId);
function notificationAlreadySent(reqId, type) {
log.addQuery('u_request', reqId);
log.addQuery('u_notification_type', type);
return log.query() && log.hasNext();
function notificationAlreadySentToday(reqId, type) {
var today = gs.nowDate();
log.addQuery('u_sent_on', '>=', today);
