Please help with Application Menus links.
Annie10
I did not know where I screwed up, but now all the questions under Create New change request under Change Management Application Menus are missing.  Can someone please help?  Thanks
User Prompt Questions:
Create Normal Change: Normal Changes are a general purpose change type that requires one or more approvals.
Standard: Select from available preapproved change templates. These changes do not require approval.
Create Emergency Change: Emergency Changes are a change type that must be implemented as soon as possible.
Hi @Riya Verma
Thank you for helping.  What I did was accidently deleted the change interceptor then I recreate the new interceptor thinking it will works the same as the one that I deleted.  However, the new interceptor I created putted in to "Global" Package instead.  Should it purpose to go into the Change Request Package?
