09-15-2023 03:36 AM
I have a requirement where i need to get the "Descripion" field and auto populate another field lets say."Description 1" but without any numbers.
For example:
if Description ----is--> General Requirement 1.1
then Description 1 ---should be---> General Requirement
Note: The content on the Description may vary and the numbers like(1.1 or 1.04) will always be at the end.
09-15-2023 04:23 AM
You can put like below
var description = "General Requirement 1.1 @%";Regex explaination :
description = description.replace(/[0-9.]/g, '');
var description_1= description;
ServiceNow Developer
- Socrates
09-15-2023 03:58 AM - edited 09-15-2023 05:00 AM
Hi @Lavanya Nagendr , use a RegEx and replace function for that.
var str = g_form.getValue('description');
var result = str.replace(/([^a-z|^A-Z|^\s]*)/gm,"").trim();
g_form.setValue('u_description_1', result);
Greets
Daniel
09-15-2023 04:08 AM
var result = str.replace(/([^a-zA-Z\s]*)/gm,"").trim();
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1393773
