print values on form using business rule
Shivani Khedek1
Giga Contributor
I have written a business rules on a custom task table, which should print error messages on form if any of the mentioned field value is not given.
for example, i have a field 'owner ' on which i have written a business rule which should mark state to closed complete if value in owner field changes. Along with this implementation I want an error message to be displayed on form below owner field that 'error assign owner'.
I have tried implementing:
gs.addErrorMessage('Form Error Message Text');
gs.addErrorMessage(gs.getMessage("Choose approval or rejection"));
gs.addErrorMessage('Choose approval or rejection');
g_form.addErrorMessage('This is an error');
current.approval.setError('Choose approval or rejection');
current.approval.setDisplayValue('Choose approval or rejection');
current.approval.setValue('Choose approval or rejection');
can someone help me to print values on form using business rule?
thank you,
Shivani.
13 REPLIES 13
when the owner field remains empty.
Create after update business rule :
Add this script :
if(current.owner =='') //Here owner should be backend value
gs.addErrorMessage("Give your message");
You can also achieve this by using OnLoad Client script :
var gr = g_form.getValue("owner");
if(gr=='')
g_form.addErrorMessage("Add message here");
Jaydeep Parmar
Use onChange() Client Script
check=g_form.getValue("owner");
if(check=="")
 g_form.addErrorMessage("Error Msg");
