Problem to convert sys_id of reference field into string
Matki
Hello everyone,
my goal is to display the cost center of the current requested for automatically in the Service Portal.
Therefore, I map the field cost_centers_clock (reference field) with the cost_center field from the user record in a client script:
How can I convert the sys_id into the name?
My code:
    if (newValue == '') {
    gr.addQuery('sys_id', newValue);
    gr.query(myCallbackFunction);
    function myCallbackFunction(gr) {
        if (gr.next()) {
           g_form.setValue('cost_centers_clock', gr.cost_center);
I have found several solutions, but they have not worked for me.
g_form.setValue('cost_centers_clock', gr.getDispayValue('cost_center'));
g_form.setValue('cost_centers_clock', gr.getDispayValue('cost_center.name'));
gr.cost_centers_clock.getDisplayValue()
// Use of GlideAjax...
Can anyone help me?
Thanks in advance!
Akshay37
Giga Guru
Try to use gr.cost_center.getDisplayValue() instead of gr.cost_center
or my recommendation is to change variable type to reference type.
Please mark it correct/helpful if this helps you
Akshay
MD AQUIB KHAN
Giga Guru
Please find the scripts below:
Script Include:
getcostCenter: function() {
var gruser = this.getParameter('sysparm_user');
gr.addQuery('sys_id', gruser);
if (gr.next()) {
var grcost = gr.getDisplayValue('cost_center');
return grcost;
Client Scripts:
if (isLoading) {
var gr = new GlideAjax('CostCentre');
gr.addParam('sysparm_name','getcostCenter');
gr.addParam('sysparm_user',newValue);
gr.getXML(callback);
function callback(response){
var answer = response.responseXML.documentElement.getAttribute('answer');
alert(answer);
g_form.setValue('cost',answer); // Please add your backend field name. Note: Here my cost center field type is single Line text
Output:
