Problem with calling function inside the same script include
Serhii5
Mega Guru
Hi guys, I have a problem with calling a function in the same script include,
slicedata: function(field) {
var table_created_on = new GlideDateTime(field);
var table_date = table_created_on.getDate();
var table_month = table_date.toString().split("-")[1];
return table_month;
and after that im trying to call this function inside another function but same script include
assigneduser: function(table, current) {
var tickets = new GlideRecord(table);
tickets.addQuery('assigned_to', current.u_user);
tickets.query();
var tickets_count = 0;
while (tickets.next()) {
var ticket = this.slicedata(table.sys_created_on).slicedMonth;
problem is - when i call function without underscore - its work, without - none.
var ticket = this._slicedata(table.sys_created_on).slicedMonth; - that's work
Could I ask you're to explain to me, why that happens?
bernyalvarado
Here goes some examples that should be able to demonstrate what I'm explaining:
Using a script include with the name testSI:
var testSI = Class.create();
testSI.prototype = {
    initialize: function() {
	sayHello: function(){
		gs.addInfoMessage('Hello');
		this._sayIntro();
		this.sayGoodbye();
	_sayIntro: function(){
		gs.addInfoMessage('I hope you are doing great');
	sayGoodbye: function(){
		gs.addInfoMessage('Good bye');
    type: 'testSI'
If externally I call the following
var testGreetings = new testSI();
testGreetings.sayHello();
the result will be
Background message, type:info, message: Hello
Background message, type:info, message: I hope you are doing great
Background message, type:info, message: Good bye
Both _sayIntro (with the underscore) and sayGoodbye are successfully called from the sayHello method
We can even call the internal method with the underscore from outside the script include... although, as previously said... if it has an underscore it's because it's not design to be called from outside but rather from within the script include, yet, it's call will be successful.
testGreetings._sayIntro();
bernyalvarado
Hi @Serhii @Serhii,
I hope you're doing great!
Within a method of a script include you can call another one regardless if it starts with an underscore (_) or not. Using the underscore as a prefix of a method is just a best practice to have a visual aid of which methods are intended for internal use within your script include. It's not the same as using private in a class or struct in other programming languages because you can still call the method with underscore outside of the script include.
I hope this helps! 🙂
Berny
bernyalvarado
		this._sayIntro();
		this.sayGoodbye();
    type: 'testSI'
the result will be
Yes, thanks a lot for your answer, I decided my problem, it was inside script include
Cool! You're welcome! 🙂
