Problem with REST Step in Flow Designer
‎09-15-2022 01:29 AM
Hi. I have an action which has a REST Step that calls to a third-party API. The problem is that these characters %EF%BB%BF are appended to the URL.
For example:
https://ipinfo.io/8.8.8.8%EF%BB%BF/json
8.8.8.8 is an input. Because of the appended characters, this error appeared:
Invalid uri 'https://ipinfo.io/8.8.8.8/json': escaped absolute path not valid
Now, I've already managed to remove the characters from the URL but I need to know what is the cause of this because in other devices, this does not occur. Has anyone encountered this?
- 12,271 Views
‎09-22-2022 05:33 AM
Yes, engineering is actively working on the issue. I'll try to update this post when there is a resolution.
‎09-22-2022 09:43 AM
Unfortunately, I am unable to downgrade or use FireFox or Safari due to the regulated policy at my place of work.
It is more feasible if ServiceNow provides a fix or workaround. This is causing a road block in a project.
Thank you,
Harriet
‎09-23-2022 05:40 AM
‎10-18-2022 03:45 PM
@Harriet K Please check my previous reply to @Scot Eagle. Maybe it helps.
‎10-18-2022 04:25 PM
Hi, @Brunno Santos! Thank you for the information! I appreciate it.
I actually ended up requesting for approval to get Firefox installed. Thankfully, it was approved after providing extensive business justification. I will bookmark your workaround though as it is a good backup solution, just in case!
