Problems with Powershell Invoke-WebRequest
simonapa
Mega Contributor
Hello! We have a large number of Powershell scripts supporting our environment, I am working on a new functionality that integrates a more to ServiceNow but have hit a wall.
One script has a number of requirements that will require interaction with SN.
1. Updating/writing to an existing ticket.
2. Searching for a ticket.
3. Reading from a ticket.
From the server that executes the scripts, I am getting errors:
Invoke-WebRequest : The underlying connection was closed: An unexpected error occurred on a send.
At line:23 char:13
+ $response = Invoke-WebRequest -Headers $headers -Method $method -Uri $uri -proxy ...
      + CategoryInfo                   : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebException
      + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
<code>
# Eg. User name="admin", Password="admin" for this code sample.
$user = "admin"
$pass = "admin"
# added the following line to add path to proxy
$proxy = 'http://proxy.url:8080'
$base64AuthInfo = [Convert]::ToBase64String([Text.Encoding]::ASCII.GetBytes(("{0}:{1}" -f $user, $pass)))
# this was added to assist with SSL Trust message
[System.Net.ServicePointManager]::ServerCertificateValidationCallback = {$true}
$headers = New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
$headers.Add('Authorization',('Basic {0}' -f $base64AuthInfo))
$headers.Add('Accept','application/json')
$uri = https://instance.service-now.com/api/now/table/incident?sysparm_limit=1
$method = "get"
$response = Invoke-WebRequest -Headers $headers -Method $method -Uri $uri -proxy $proxy -ProxyUseDefaultCredentials
</code>
Where have I gone wrong? Any assistance would be appreciated.
simonapa
Mega Contributor
Hello everyone, I wanted to share the workaround to this issue.
By adding the following to the my script I am able to get full functionality to our instance.
<code>
      Add-Type @"
      using System;
      using System.Net;
      using System.Net.Security;
      using System.Security.Cryptography.X509Certificates;
      public class ServerCertificateValidationCallback
              public static void Ignore()
                      ServicePointManager.ServerCertificateValidationCallback +=
                              delegate
                                      Object obj,
                                      X509Certificate certificate,
                                      X509Chain chain,
                                      SslPolicyErrors errors
                                      return true;
[ServerCertificateValidationCallback]::Ignore();
</code>
I hope this helps someone else out too.
Hi simonapa
Can you show me where i put this example code in this exemple down ?  thanks
</code>
$user = "admin"
$pass = "admin"
$method = "get"
</code>
